Forgot To Dilute KBS Klean With Water. What Should I Do?
If you applied KBS Klean undiluted, rinse the surface thoroughly with clean water and a green scotch brite type pad. KBS Klean is a concentrate and should always be diluted with water, warm or hot is best, at a minimum of 1 to 1 for maximum effectiveness, so a good rinse will remove any leftover residue without damaging the surface.
Quick fix: Rinse the surface with clean water using a green scotch brite type pad. This removes residue from undiluted product and preps the surface for your next step.
Why Dilution Matters With KBS Klean
KBS Klean is a concentrated, water-based cleaner and degreaser, so it is designed to be mixed with water rather than applied straight from the container. Diluting it lets the cleaner spread evenly across the surface and rinse away completely, leaving no residue that could interfere with paint or coating adhesion. Using it at full strength does not damage most surfaces, but it can leave more residue behind, which is why a thorough water rinse afterward is the right fix.
Recommended KBS Klean Dilution Ratios
Surface ConditionWaterKBS Klean
Heavily soiled surfaces1 part hot water1 part
Moderately soiled surfaces5 parts hot water1 part
Lightly soiled surfaces10 parts hot water1 part
Non-ferrous metals (aluminum, copper, brass)25 parts hot water1 part
Pro tip: Warmer water improves cleaning power. Do not let KBS Klean dry on the surface before rinsing, and always rinse thoroughly with clean water when finished.
Next Steps
Once the surface has been rinsed clean, you're ready to move on. If you're prepping bare or lightly rusted metal for painting, treat it with RustBlast before applying RustSeal to ensure proper adhesion.
For full mixing ratios, soak times, and surface-specific instructions, see the complete KBS Klean Application Directions.
What should I do if I forgot to dilute KBS Klean with water?
Rinse the surface thoroughly with clean water using a green scotch brite type pad. This removes any residue left behind from using KBS Klean at full strength and will not damage the surface.
Does KBS Klean need to be diluted with water?
Yes. KBS Klean is a concentrate and should always be diluted with water, warm or hot water works best, at a minimum of 1 to 1 for maximum effectiveness.
What dilution ratio should I use with KBS Klean?
Use 1 part hot water to 1 part KBS Klean for heavily soiled surfaces, 5 parts hot water to 1 part KBS Klean for moderately soiled surfaces, 10 parts hot water to 1 part KBS Klean for lightly soiled surfaces, and 25 parts hot water to 1 part KBS Klean for non-ferrous metals like aluminum, copper, and brass.
Can using KBS Klean undiluted damage the surface?
In most cases a thorough rinse with clean water and a green scotch brite type pad will resolve it. If you have concerns about a specific surface, such as non-ferrous metals, reach out to KBS Coatings support before proceeding.
Ready to Get a Clean, Residue-Free Surface?
Shop KBS Klean or check out the full application directions for your next project.
Shop KBS Klean View Directions
