Can I use KBS Klean full strength or is KBS Klean always supposed to be diluted?
KBS Klean is designed to be diluted with water rather than used straight from the container. A full-strength dilution is 1 part hot water to 1 part KBS Klean, but depending on the job you can go as light as 10 parts water to 1 part KBS Klean, or even 25 parts water to 1 part KBS Klean.
Dilution Best for
1 part hot water : 1 part KBS Klean Full strength — heavy grease and grime
10 parts hot water : 1 part KBS Klean Moderate general cleaning
25 parts water : 1 part KBS Klean Light cleaning jobs
Pro Tip
Start with a lighter dilution for general cleaning and move up to full strength only when you're dealing with heavy grease, oil, or baked-on grime. A little KBS Klean concentrate goes a long way.
Review the complete KBS Klean Directions before you begin your project.
Can I use KBS Klean full strength, or does it always need to be diluted?
KBS Klean is designed to be diluted with water. A full-strength mix is 1 part hot water to 1 part KBS Klean. Depending on the job, you can dilute it further, up to 10 parts water to 1 part KBS Klean, or even 25 parts water to 1 part KBS Klean for light cleaning.
What is the most diluted ratio I can use for KBS Klean?
For light cleaning jobs, KBS Klean can be diluted up to 25 parts water to 1 part KBS Klean and still be effective.
What dilution ratio should I use for heavy grease and grime?
For the toughest jobs, use KBS Klean at full strength: 1 part hot water to 1 part KBS Klean.
Get the Dilution Right Every Time
One concentrated bottle of KBS Klean stretches across dozens of jobs when diluted correctly.
