My tank has an internal fuel pump and fuel strainer assembly consisting of a mix of plastic and metal parts. Is it safe to use KBS Klean on these parts?
Yes — you can absolutely use KBS Klean on the plastic and metal parts inside a tank with an internal fuel pump and strainer assembly. KBS Klean will not harm plastic, and you can run it safely through the fuel pump to clean it out along with the rest of the tank.
Safe on Mixed Materials
Whether the internal assembly is plastic, metal, or a mix of both, KBS Klean will not damage those components. It can be flushed through the fuel pump itself to clean out residue and debris.
If you're cleaning the tank as part of a full rust prevention and sealing project, KBS Klean is the first step of the KBS Tank Sealer System. Review the complete Tank Sealer Directions for the full process, and reach out if you have additional questions.
Is it safe to use KBS Klean on a fuel pump and strainer assembly with plastic and metal parts?
Yes. KBS Klean will not harm the plastic or metal parts of an internal fuel pump and strainer assembly. You can also run KBS Klean safely through the fuel pump to clean it out.
Will KBS Klean damage plastic fuel system components?
No, KBS Klean will not harm plastic parts, making it safe to use on tanks with internal plastic fuel pump and strainer assemblies.
Do I still need to follow the full Tank Sealer process if my tank has an internal fuel pump?
Yes. Clean the tank with KBS Klean, including running it through the fuel pump assembly, then follow the complete KBS Tank Sealer Directions for the full prep and sealing process.
Cleaning a Tank With Internal Components?
KBS Klean safely cleans plastic and metal fuel system parts as step one of the complete Tank Sealer System.
Shop Tank Sealer View Tank Sealer Directions
