Will KBS Klean work on unpainted aluminum?
Yes — KBS Klean is ideal for cleaning unpainted aluminum surfaces. The best practice is to mix 25 parts hot water to 1 part KBS Klean and clean with a very soft, non-abrasive cleaning pad. Rinse the solution off immediately, don't let it sit on the surface and air dry, to minimize the chance of water stains.
Aluminum Cleaning Ratio
25 parts hot water to 1 part KBS Klean, applied with a soft, non-abrasive pad, is the recommended dilution for unpainted aluminum.
Pro Tip
Rinse immediately after cleaning. Letting the solution sit and air dry on aluminum is what causes water stains, not the cleaner itself.
Review the complete KBS Klean Directions before starting your project.
Yes. KBS Klean is ideal for cleaning unpainted aluminum surfaces. Mix 25 parts hot water to 1 part KBS Klean and clean with a very soft, non-abrasive pad.
How do I avoid water stains when cleaning aluminum with KBS Klean?
Rinse the KBS Klean solution off immediately after cleaning. Do not let it sit on the aluminum surface and air dry, as that increases the chance of water stains.
What dilution ratio should I use for cleaning aluminum with KBS Klean?
For unpainted aluminum, the best practice is 25 parts hot water to 1 part KBS Klean, used with a soft, non-abrasive cleaning pad.
Get a Clean, Streak-Free Aluminum Finish
The right dilution and a soft pad give you a clean aluminum surface without stains or scratches.
