No. XTC and Motor Coater are two different paint chemistries built for surfaces that operate in very different temperature ranges, and they are not designed to be applied one over the other.
| Why they don't mix: Motor Coater is a ceramic-resin engine enamel rated to 500°F, formulated for engine blocks, transmissions, and other underhood components. XTC is a silicone resin-based coating engineered for continuous service from 500°F up to 1500°F, built for headers, exhaust manifolds, and exhaust pipes. Different resin systems, different temperature jobs. Layering one over the other isn't a supported application. |
Motor Coater vs. XTC: Different Coatings for Different Heat Zones
It's an easy mix-up because both products live under the hood, but they're built to solve different problems. Motor Coater is a high-gloss, self-leveling engine enamel designed for engine blocks, calipers, and underhood components that see temperatures up to 500°F. XTC is a silicone resin-based coating designed for the much hotter surfaces further down the exhaust path, holding up to continuous temperatures from 500°F to 1500°F.
| Note for body shops: XTC is a silicone resin coating, worth calling out plainly since silicone is a familiar red flag around a paint booth. The fisheye risk shops watch for comes from free, uncured silicone, oils, mold releases, lubricants, and detailing sprays that transfer onto a panel before paint goes on. A fully cured, crosslinked silicone resin coating like XTC is a different situation than loose silicone contamination. |
| Product | Chemistry | Temperature Rating | Typical Use |
| Motor Coater | Ceramic-resin enamel | Up to 500°F | Engine blocks, transmissions, calipers, underhood parts |
| XTC | Silicone resin-based | 500°F to 1500°F continuous (1200°F for aerosol/primer) | Headers, exhaust manifolds, exhaust pipes |
| DiamondFinish Clear | 1K moisture-cured urethane | Up to 300°F | Optional clear coat over cured Motor Coater |
If your surface runs hotter than 500°F, such as headers, manifolds, or exhaust pipes, XTC is the correct product on its own. It isn't meant to be paired with Motor Coater as a clear topcoat.
Does Motor Coater Need a Clear Coat to Look Glossy?
No. Every Motor Coater color is glossy right out of the can, with one exception: Velvet Black, which is a matte finish. You do not need to add any clear coat to get a high-gloss, show-quality finish on the other 40+ Motor Coater colors.
| Pro Tip: If you want more depth of gloss or added durability on top of Motor Coater, let the Motor Coater cure for at least 7 days first, then apply DiamondFinish Clear. It's rated to 300°F, more than enough for a water-cooled engine. |
Adding Depth of Gloss to Motor Coater the Right Way
If you still want to clear coat Motor Coater purely for extra depth or protection, the compatible product is DiamondFinish Clear, not XTC. Here's how:
| Step | What to Do |
| 1 | Apply Motor Coater and allow it to cure for at least 7 days. |
| 2 | Apply DiamondFinish Clear directly over the cured Motor Coater. |
| 3 | DiamondFinish Clear is rated to 300°F, which comfortably covers the surface temperatures of a water-cooled engine. |
For full application details, see the Motor Coater application directions and the DiamondFinish Clear product page.
Can XTC Clear be applied over Motor Coater?
No. XTC and Motor Coater are two very different paint chemistries designed for surfaces operating in much different temperature ranges. Motor Coater is a ceramic-resin engine enamel rated to 500°F, while XTC is a silicone resin-based coating built for continuous service from 500°F to 1500°F on headers and exhaust components. They are not designed to be layered over one another.
Do all colors of Motor Coater need a clear coat to look glossy?
No. Every Motor Coater color is glossy on its own except Velvet Black, which is a matte finish. A clear coat is not required to achieve a high-gloss look on any other Motor Coater color.
Can I clear coat Motor Coater if I want more depth of gloss?
Yes. If you want additional depth of gloss or extra durability, let Motor Coater cure for at least 7 days, then apply DiamondFinish Clear over it. DiamondFinish Clear is rated to 300°F, which is more than enough for a water-cooled automotive engine.
Is DiamondFinish Clear heat resistant enough for an engine?
Yes. DiamondFinish Clear is rated to 300°F, well above the surface temperatures a water-cooled engine block, cylinder heads, or brake calipers typically reach. It is not intended for header or exhaust surfaces, which require XTC instead.
What should I use to coat headers and exhaust components instead of Motor Coater?
Use XTC. XTC is a silicone resin-based coating engineered for continuous service from 500°F to 1500°F, which covers the higher surface temperatures found on headers, exhaust manifolds, and exhaust pipes. Motor Coater is rated only to 500°F and is intended for engine blocks, transmissions, and other underhood components, not direct exhaust surfaces.
Ready to Give Your Engine a Show-Quality Finish? Shop Motor Coater in 40+ OEM colors, or pick up DiamondFinish Clear to add extra depth of gloss. |
