Yes, XTC is a great choice for mufflers. Start with a coat of XTC Primer to provide the rust protection base, then follow up with 1 to 2 coats of XTC as your finish coat.
Pro Tip Always apply thin coats, never heavy coats. Thin coats cure properly and bond better, especially on high-heat surfaces like mufflers. |
Before you begin, review the complete application and temperature cure instructions for both products.
Ready to Coat Your Muffler? Get the full directions for XTC Primer and XTC, then shop everything you need for your muffler project. XTC & XTC Primer DirectionsShop XTC Coatings |
