Bake RustSeal To Speed Cure
RustSeal is a moisture cured urethane (catalyzed by moisture in the air), so dry heat from baking can actually slow the cure of RustSeal.
Pro Tip: Heat Slows the Cure, Humidity Speeds It
You can speed the cure of RustSeal with air flow and humidity (a humidifier, wet towels on the ground, etc.) — not heat. Always allow RustSeal to cure normally until it is dry-to-touch and does not leave a fingerprint before adding air flow and humidity.
Ready to Apply RustSeal?
Shop RustSeal and follow the full application directions for the best cure results.
Shop RustSealView Application Directions
