Is DiamondFinish Clear Aerosol Impervious To Fuels
DiamondFinish Clear Aerosol is a tough, water-clear clear coat that can be applied Direct To Ferrous Metals and Aluminum — or over other coatings — and will not yellow, crack, or peel. It uses a professional-grade acrylic resin system for supreme clarity and adhesion, and is impervious to most solvents and oils.
⚠ Not Recommended for Fuel Contact
While DiamondFinish Clear Aerosol resists most solvents and oils, it is not recommended where there will be substantial contact with fuel. Fuel is quite harsh and can wrinkle the coating under prolonged or heavy exposure.
If you have an application requiring a clear coat that will withstand substantial fuel contact, we recommend reaching out to our team directly. We'll help identify the right product for your specific situation.
Is DiamondFinish Clear Aerosol fuel resistant?
DiamondFinish Clear Aerosol is impervious to most solvents and oils, but it is not recommended for applications with substantial fuel contact. Fuel is quite harsh and can wrinkle the coating when there is prolonged or heavy exposure.
Can DiamondFinish Clear Aerosol be used on fuel tanks?
DiamondFinish Clear Aerosol is not recommended where there will be substantial fuel contact. If you need a clear coat that will withstand fuel exposure, contact KBS Coatings so we can guide you to the right product for your specific application.
What surfaces can DiamondFinish Clear Aerosol be applied to?
DiamondFinish Clear Aerosol can be applied Direct To Ferrous Metals and Aluminum, or over other coatings. It is a water-clear aerosol clear coat using a professional-grade acrylic resin system for supreme clarity and adhesion.
Will DiamondFinish Clear Aerosol yellow, crack, or peel?
No. DiamondFinish Clear Aerosol does not yellow, crack, or peel — making it a durable long-term clear coat for most applications outside of heavy fuel exposure.
Ready to get started?
Review the full application directions before you begin, or contact our team if you're unsure which product is right for your project.
Shop DiamondFinish Clear Aerosol Application Directions Contact Us
