Yes, you can coat over Fusion SEP with an enamel paint (like Motor Coater) and then a clear coat (like DiamondFinish Clear).
Pro Tip: Don't Skip the Cure Window Let Fusion SEP cure for a full 1 hour before applying your enamel paint. Topcoating too soon can compromise adhesion between the primer and finish coat. |
Before you begin, review the complete Fusion SEP application instructions for full prep and cure guidance.
Ready to Build Your Finish? Get the full Fusion SEP directions and shop the complete system: primer, enamel, and clear coat. Fusion SEP DirectionsShop Fusion SEPShop Motor CoaterShop DiamondFinish Clear |
