Does KBS Patch stick to RustSeal?
Yes, KBS Patch bonds permanently to RustSeal when properly prepared. Follow these steps for maximum adhesion:
  • Allow RustSeal to fully cure for at least 24 hours.
  • Keep the cured surface clean and free of contamination before proceeding.
  • Scuff the cured RustSeal lightly with 300 grit sandpaper.
  • Apply KBS Patch to the scuffed surface and allow it to UV cure.
Once UV cured, the bond between KBS Patch and RustSeal is permanent and exceptionally strong.
Review the complete KBS Patch Application Directions before starting your project.
A Permanent Repair, Done Right
RustSeal stops rust and creates the ideal base. KBS Patch fills, bonds, and UV cures to a permanent finish.
Shop KBS Patch Shop RustSeal
