Shop
Reseller Finder
My Support Tickets
Submit Question
My Cart
XTC and XTC Primer - Xtreme Temperature Coating
I like the color of XTC Primer. Do I have to coat over it?
XTC Primer is 100% UV stable, looks great brushed or sprayed out, and can be left as a finish coat if desired. +Read More.
If I paint exhaust headers with the XTC Primer and XTC, can I do an exhaust wrap after the XTC is properly cured?
Once XTC is fully cured, you can put an exhaust wrap over the surface. +Read More.
Can XTC be used to paint the exhaust on a Harley Davison?
Coating a motorcycle exhaust is a very common application for XTC Primer and XTC. +Read More.
I am looking to apply XTC to a furnace exterior. Can the temperature curing be done by burning the furnace at a low temperature? How long?
You can heat cure XTC by starting a fire to get the surface to 350F for at least 30 minutes. +Read More.
Does XTC Primer have to be temperature cured before XTC is applied?
In this article, we describe the timing on when you should do the temperature cure when you are applying XTC Primer and then XTC. +Read More.
If I paint exhaust headers with the XTC Primer and XTC paint, will it be okay to do an exhaust wrap after the paint is properly cured?
XTC Primer and XTC from KBS Coatings can be use to prime and paint an exhaust before you put a heat wrap over the surface. +Read More.
May I use XTC on mufflers with light rust?
XTC Primer and XTC from KBS Coatings are an excellent coating to coat mufflers on a car, motorcycle, and so much more. +Read More.
