Second Coat Of Tank Sealer
May 09, 2025
Guest wrote
I applied Tank Sealer and then I tested my prepped and sealed gas tank with water and it still drips a tiny little bit. Can I apply another coat of Tank Sealer to get some additional coating in there to close up the small pinhole where the tank leaks?
1 Answer
Avatar image
May 09, 2025
Yes, Tank Sealer adheres very well to itself.
Because you tested the tank with water (Good Job!), all you need to do is dry the tank well. If you had introduced fuel or anything other than water to test for leaks, then you would simply need to clean out the residue in the tank with KBS Klean and rinse with water before drying the tank well.
Apply another coat of Tank Sealer following the directions being sure not to let the Tank Sealer puddle or get thick always draining out the excess. You can buy the Tank Sealer alone here 👉 https://www.kbs-coatings.com/tank-sealer
As always, carefully follow the directions so you achieve the success you desire 👉 https://www.kbs-coatings.com/tank-sealer-directions
