Can I use lacquer thinner to thin RustSeal for spraying?
Lacquer thinner is a frequently asked-about solvent, but it is not compatible with RustSeal for thinning. Here is what to use — and what to avoid.
⚠️ Do Not Use Lacquer Thinner to Thin RustSeal
Lacquer thinner is incompatible with RustSeal and can cause product failures when used as a thinner. Lacquer thinner is acceptable for clean-up only — never for thinning.
✅ Recommended Thinners for RustSeal
1st Choice — KBS #1 Thinner: Our recommended thinner, formulated for use with RustSeal.
Alternative — Xylene (Xylol): A compatible substitute if KBS #1 Thinner is not on hand. Works well for thinning RustSeal.
📋 Review the complete RustSeal Application Directions before starting your project for full mixing, thinning ratios, and application guidance.
Ready to protect your metal with RustSeal?
Shop RustSeal and KBS #1 Thinner on our website.
Shop RustSeal Shop KBS #1 Thinner
