Clear Coat For Water Immersion
Surfaces that are permanently immersed in water require a high solids, non-porous clear coat. KBS MAXX Clear is formulated for and used often on surfaces that are exposed to water and even permanently immersed in water, such as marine surfaces and swimming pools.
Before you apply KBS MAXX Clear to a surface, be sure you have wire wheeled, sanded, or otherwise removed any loose flaky coatings or debris. Then clean the surface well with KBS Klean. Once the surface is prepped and dry, apply KBS MAXX Clear in thin, covering coats — never heavy coats.
Pro Tip: Immersion Environments Need 3 Coats
For environments where water is constantly present or the surface is fully immersed, apply a minimum of three coats of KBS MAXX Clear for full protection.
Be sure to follow the complete KBS MAXX Clear Application Directions for full mixing, coverage, and cure guidance.
Ready to Apply KBS MAXX Clear?
Get long-lasting protection for marine surfaces, pools, and anything exposed to constant water contact.
Shop KBS MAXX ClearView Application Directions
