Can I reuse the Cavity Wand or is the Cavity Wand a single use item?
You can reuse the Cavity Wand almost indefinitely.
Pro Tip: Flushing the Wand
After each use, invert the Cavity Coater Aerosol can and spray through the Cavity Wand for 10 seconds to flush out residual product. This keeps the wand clear and ready for next time.
If you do this, the Cavity Wand will be ready to use the next time it is needed.
For full application instructions, see the Cavity Coater Directions.
