Yes, KBS Paint Spouts are fully impervious to solvent based coatings and can be used with them without any issues.
Cleanup is just as easy as with any other coating: allow the solvent based paint to fully cure on the spout, then bend it back and forth. The dried coating will crack and fall off cleanly with no solvents needed, leaving the spout ready to use again.
A Smarter Way to Pour
Compatible with solvent and water based coatings alike, the KBS Paint Spout delivers clean, precise pours and reuses up to 25 times: less mess, less waste on every project.
Shop KBS Paint Spout View All Supplies
