Do the Brush Mark Really Flow Out When Brushing DiamondFinish Clear?
Yes, DiamondFinish Clear is a simple to use 1K Clear Coat that is designed to be applied by brush and look like it has been sprayed.
When brushing DiamondFinish Clear, apply thin, covering coats and do not overwork the brush as this can cause the DiamondFinish Clear to cure too quickly possibly leaving visible brush marks. It is best to brush an area with DiamondFinish Clear and move on immediately versus brushing an area over and over again. If you brush over an area over and over again forcing the solvents out, you run the risk of the brush marks not flowing out as well they are designed to flow out. Thinning is not generally required if brushing but if you need to help flow out, you can thin/reduce roughly 10%.
DiamondFinish Clear is a long lasting, moisture cured clear coat designed to add body, depth, and a rich gloss.
DiamondFinish Clear is guaranteed to never yellow or crack because it is 100% UV stable.
DiamondFinish Clear is exceptionally durable due to its high solids content meaning better coverage, but at the same time will always remain highly flexible.
DiamondFinish Clear is excellent for suspending glitter in any finishes.
Please be sure to review the Complete DiamondFinish Clear Application Directions before you begin your project.
