In What Temperatures Can I Apply RustSeal?
RustSeal has been thoroughly tested and can be applied with the RustSeal (in the can or container), air, and surfaces temperatures are between 55F-82F. In addition to temperature, the relative humidity should be between 30-80 RH.
  • The surface temperature is typically less than the air temperature. Make sure both surface and are temperatures are within the range of 55-82F.
  • If the temperature is too high, the solvents in RustSeal can evaporate too quickly causing a less than ideal looking finish and possible adhesion issues.
  • If the humidity is below 30RH, RustSeal may take much longer to cure which can cause a less than ideal looking finish.
  • If the humidity is above 80RH, RustSeal make cure too quickly causing a less than ideal looking finish and possible adhesion issues.
  • When temperature and humidity may be out of the range of 55-82F and 30-80RH, always do the actual application when the surface and air temperature and humidity are within those ranges.
    • If the temperature or humidity is too low, please allow extra cure time beyond what the RustSeal Directions state.
  • Always allow RustSeal to get to 55-82F before application.
  • RustSeal can be shipped or stored in below freezing temperatures with absolutely no affect on the RustSeal. Always allow RustSeal to get to 55-82F before application.
RustSeal Product Link 👉 https://www.kbs-coatings.com/rustseal.html
Please review the complete RustSeal Application Directions before you begin your project and do not hesitate to Reach Out if you have any questions.
