What is the coverage for DiamondFinish Clear?
For DiamondFinish Clear, theoretical coverage at one mil (25 µm) is 400 sq.ft. per gallon/9.8 m² per liter. Recommended thickness of at least two mils (50 µm) would require at least two full coats. At least three coats are recommended for marine applications. Material losses during mixing and application will vary and must be taken into consideration. Please expect up to 50% less coverage on bare wood, rough, or sandblasted surfaces.
4oz of DiamondFinish Clear should cover 12.5 sq. ft. single coat coverage.
Pint of DiamondFinish Clear should cover 50 sq. ft. single coat coverage.
Quart of DiamondFinish Clear should cover 100 sq. ft. single coat coverage.
Gallon of DiamondFinish Clear should cover 400 sq. ft. single coat coverage.
5 Gallon Pail of DiamondFinish Clear should cover 2000 sq. ft. single coat coverage.
